In the wastewater treatment industry, it is commonly accepted that 90 percent of electrical faults begin as ground faults. Early detection of ground faults and deteriorating equipment integrity can minimize equipment damage, enable predictive maintenance, prevent escalation to a dangerous arc fault scenario and, ultimately, ensure the protection of personnel. An ungrounded power system has no point of the system intentionally bonded to ground. An optimal ground fault detection solution is found in the insulation monitoring device (IMD), offering low-level (Mega-ohm and below) detection of early-stage faults, including when only a single fault is present. In grounded power systems, typically the system wye-point or artificially derived neutral is bonded to ground, either solidly grounded or impedance grounded. In this system type, optimal ground fault detection solutions use ground fault current sensors with low-level (sub-ampere) detection of early-stage faults. A variable frequency drive (VFD) creates a mixed alternating current/direct current (AC/DC) system by rectifying an AC voltage to DC, then inverting the DC voltage to AC. The output is controlled to manage the connected load. A ground fault in such a system can be AC, DC or a combination of both. A ground fault at the drive output terminals, in the cable to the motor or in the motor itself, will have a fundamental frequency equal to the drive-output operating frequency. Electrical noise resulting from the power-electronics switching may also be superimposed. Additionally, a VFD’s operating (carrier) frequency may inadvertently impress harmonics onto the system. Ground fault detectors must overcome these challenges and still perform with precision. One of the largest wastewater treatment facilities in British Columbia presented such a challenging environment. The facility required a solution for detecting AC and DC faults, operating while the system was both online and offline, and remaining immune to VFD harmonics. When implemented, the solution would allow maintenance personnel to find and correct insulation deterioration in the early stages, reducing the opportunities for further damage and avoiding expensive and unscheduled stoppages.
Ground fault detectors provide economic efficiency by improving operational availability.
Bender Inc.
07/03/2018
