What is an eddy current drive? An eddy current drive, also known generically as a magnetic drive, eddy current clutch or magnetic clutch, is an electro-mechanical variable speed drive that uses a constant speed motor as the input. The eddy current drive is installed between the motor and the driven equipment. Torque is transmitted to a variable speed output in proportion to a direct current (DC) applied to a set of coils on the output’s rotor. This method of varying speed only reduces the speed of the driven load, which is different than variable frequency drives and DC drives, which vary the speed of both the motor and driven load by electronically altering the input power to motor. Horizontal eddy current drives can either be flange-coupled to the motor or may be separately mounted in a shaft-coupled configuration. In a typical vertical configuration, shown in Image 3, an ordinary induction motor is mounted atop the eddy current drive. The eddy current drive is built within a stationary frame of fabricated or cast steel, with a lower flange and shaft similar to that of a vertical motor.
