Liquid transfer specialists often receive a call that a pump seal has failed and is spraying fluid all over the place. At hundreds of plants every year, liquid transfer specialists are taken to a pump room with product being transferred because multiple pumps are leaking and dripping due to the sealing device not working correctly. This problem usually results in lost production time and numerous maintenance hours. It is normally remedied with the same repair components that did not hold up to desired life expectancy in the first place. Many plants are combining the efforts of the reliability engineer and maintenance personnel; therefore, these problems are being addressed. Plant personnel are looking for viable solutions that also have a direct payback on uptime and maintenance costs once the sealing problem is resolved, and not just extemporized with the same failing component. This effort can be strengthened when the reliability or maintenance team also partners with a distributor liquid transfer specialist and the manufacturer’s representative for specialized expertise. Here is an example.
Case Study
The pump user, a manufacturer in the steel and aluminum industry, had multiple vertical turbine pumps in a pump room and there was many different approaches applied to seal these pumps. Some were packed, some had cyclonic separators and many variations of mechanical seals were used. But it seemed that none of these efforts to seal the pump addressed the actual problem that was causing the sealing issue. The group looked for the root cause of the problem, found it and pooled their experiences of application, design and engineering to develop an approach that addressed the root cause. In this application, it was determined that the vertical single rotary (VSR) cartridge mechanical seal and an application management system would not only identify some of the root cause problems, but also come up with a standardized solution for the multiple vertical turbine pumps. Multiple man-hours would not be used to remove the pumps from the application in order to accomplish the repair. The management system’s reliability was key in focusing the efforts of equipment verification, product recommendations, product training and inventory control. The application at its root cause had excessive runout as its main issue. The VSR was ideal for the application due to its ability to eliminate the housekeeping issues and extending the mean time between repair/replace (MTBR) from six to eight months to more than three years. As a single external cartridge-mounted rotary seal, the VSR is designed for installations where shaft deflection exceeds the limits allowed by off-the-shelf cartridge seals. Excessive radial clearances designed in the seal make it ideal for vertical turbine pumps in power plants, pulp and paper mills, municipalities and applications in relatively clean, lubricating fluids. Whether sealed with compression packing or a mechanical seal, the issue with sealing vertical turbine pumps is that as the bushings wear, the amount of runout they encounter exceeds the limitations of the sealing device. Compression packing is soft and as the runout increases, it opens the inner diameter (ID) of the rings, creating a leak path along the shaft. This requires constant gland adjustments, which creates wear on the shaft. When using a standard cartridge-mounted mechanical seal or a split seal, the excessive runout exceeds the clearances of the internal components, causing the seal to fail prematurely. The plant now has a dry pump room as well as an increase in reliability and runtime. Another result was the decrease in the number of storeroom items stocked for all of the different solutions that had been implemented.
Other Situations
Not every problem has an immediate resolution such as this. Often, there may be multiple problems within the pumping system that needs to be solved one at a time before the next is identified. Every study is a per-application basis for which the factors creating problems within the sealing mechanism have to be identified. These factors may include:- temperature
- viscosity
- abrasives
- lubricity of the material being pumped
- chemical compatibility
