Q. What are the best materials to use in pump construction to minimize part corrosion? A. Factors to consider in the selection of materials for wetted pump components include user's experience, life cycle costs, regulatory agency requirements (i.e. limits on lead content in bronzes that contact drinking water), required pump life, duty cycle (operating hours per period), corrosive and/or erosive properties of the fluid, hazardous nature of the fluid, the potential for cavitation, and contamination of the fluid. Corrosive and/or erosive properties of fluids may vary with temperature, concentration of chemicals or solids, the properties of the solids, velocity, and the extent of entrained gasses. Some frequently used materials are listed below.
- Bronze-fitted pump:The casing is cast iron, and the impeller and impeller rings are made of bronze. This combination is commonly used for fresh water at ambient temperatures.
- All bronze pump: All pump parts in direct contact with the pumped liquid are made of manufacturer's standard bronze. This type is often used for pumping seawater.
- All iron pump:All pump parts in direct contact with the pumped liquid are made of ferrous metal (cast iron/ductile iron, carbon steel or low-alloy steel). This pump is commonly used in hydrocarbon services and some chemical applications.
- Stainless steel fitted pump: The casing is made of materials suitable for the service. The impellers, impeller rings and shaft sleeves (if used) are made of corrosion-resistant steel with suitable properties for the application. This type of pump is also used in hydrocarbon and chemical services.
- All stainless steel pump:All pump parts in direct contact with the pumped liquid are made of corrosion-resistant steel with suitable properties for the specific application. This pump is commonly used in chemical applications.
- Rigid polymers/composites:All pump parts in direct contact with the liquid are made of rigid polymers or composites (plastics), either as coatings or as structural material. This pump type is commonly used in chemical services.
