The quality of the world’s sewage systems in past years has been influenced by four main factors: design of the system of pipes and valves, the design of the pump sump, the operation concept and the pump itself—including impeller type and design. Today, additional influences require new consideration. In some cases, worldwide wastewater pumping stations that worked well in years past (sometimes 10 or more) are now struggling because of new sewage handling challenges. In general, the composition of today’s sewage is different than that of previous years with an ongoing trend. The availability and increased use of “non-flushable” wipes in daily processes places added load on sewage handling systems. At the same time, the global pump industry is moving steadily toward a sustainable environment that requires low energy consumption and high efficiency for all energy-relevant machines and processes. In developing countries, water and wastewater technologies are improving the quality of life for many communities. As more people become connected to water sources and wastewater disposal systems, an increasing variety of items are being disposed of via sewerage. The positive trend of water supply and wastewater disposal goes hand in hand with new behavior that results from modern conveniences. This new behavior is changing sewage composition. In many cases, increased use of wastewater infrastructure leads to uncontrolled input into sewers. Plastic bags, hygienic articles and, in extreme cases, even tires from cars are found in sewer systems that were not designed to handle the extended load these items place on the system.
