Teck Resources, Ltd., operates the Teck Highland Valley Copper (THVC) mine located near Logan Lake, British Columbia, Canada. To facilitate efficient mine production, the senior foreman of Mine Services faced the challenge of continuously dewatering the surface of the largest open-pit mine in North America. The traditional approach to dewatering requires a series of centrifugal pumps to lift the collected water to the top of the mine for processing. One of the original THVC dewatering systems consisted of five multistage centrifugal pumps (four pumps at 60 horsepower and one pump at 25 horsepower), operating an average of 20 hours per day (1,364 kilowatt hours per day) to remove the water from the open-pit copper mine. The surface water contains abrasive solids that accelerated wear on the centrifugal pumps, requiring THVC to rebuild the pumps as often as once per month and to replace the pumps, often twice each year. Every year, THVC spent approximately $160,000 to maintain the system and consumed approximately 1,550,000 kilowatt hours of electricity to power it. The senior foreman at THVC believed a more reliable solution to this challenge was possible. To improve the efficiency of the dewatering effort at THVC, the senior foreman selected a pump package powered by one progressing cavity (PC) pump to replace the five-pump centrifugal system. In the first year of operation, the new dewatering system only required scheduled inspections and periodic lubrication of the bearings. No parts required replacement, which resulted in a $160,000 reduction in maintenance costs. An additional benefit was that the PC-pump system only required 358,000 kilowatt hours, which was a 77-percent reduction in power compared to the centrifugal pumps, approximately $88,000 in savings.
Background
The Solution
The THVC team approached this application with professional scrutiny to ensure confidence in using one pump to transfer so much water at high discharge pressure. Surprisingly, many engineers and the mine foreman in North America were unfamiliar with the reliability and cost benefits of PC pumps. Mining operations in the U.K., Europe, Australia, Asia and Africa have used PC pumps for decades in dewatering applications. PC pumps are ideal for dewatering because of their high reliability and life because they operate at a slow speed, reducing wear caused by abrasive particles, and their ability to handle solids in the fluid. This application of PC pumps at THVC demonstrated the difference in reliability between the 3,600-rpm centrifugal pumps and the 450-rpm PC pump. PC pumps are positive displacement, so they continuously generate discharge pressure at different flow rates, regardless of pump speed.
