In issuing its final rule on an energy conservation standard for commercial and industrial water pumps, the U.S. Department of Energy (DOE) estimates the net value of the rule to be between $74 million and $96 million per year. This estimate takes into account the energy savings from more efficient equipment and the benefits of emissions reductions during the 30-year period between 2020 and 2049. The goal of the rule, which takes effect in 2020, is to improve security and reliability of the nation's energy system by reducing demand. According to the DOE, energy savings will produce environmental benefits by reducing emissions of pollutants and greenhouse gases. This rule will reduce pump operating costs and reduce carbon emissions related to power generation, but it will also have significant impact on pump manufacturers and their customers. The cost of pump hydraulic redesign, testing and new materials is estimated at $81.2 million through 2049, according to the DOE. Manufacturers have been anticipating the changes since the first steps in 2011. Before this rule, no federal standards or test procedures existed for commercial and industrial pumps. The DOE states that the new standards will result in significant conservation of energy and that they are technologically feasible and economically justified. The department also said the final rule's standards will not result in adverse impacts on competition within the pump marketplace, significantly affect manufacturing capacity or lead to employment loss. Pump industry experts engaged in the Hydraulic Institute (HI) have worked closely with the DOE through this years-long rulemaking process, offering unprecedented cooperation among government, environmental and industry leaders. With an estimated 20 percent or more of the electricity in the U.S. consumed by commercial and industrial water pumps, manufacturers acknowledge the need to create more energy-efficient products. Representing more than 450 pump manufacturers in 38 states, HI has worked to ensure the regulations meet efficiency standards without creating financial hardships for its members. Although some U.S. manufacturers have taken steps toward greater efficiency through portfolio redesign, the lack of federal regulation has created inconsistency. The new regulations reflect those put in place in the European Union (EU) in 2009. HI's Pump Efficiency Expert Team, known as PEET, provided the DOE with extensive research about EU standards and other primary efficiency data relevant to the proposed changes. HI's involvement included representation on the DOE Appliance Standards and Rulemaking Federal Advisory Committee (ASRAC) Commercial and Industrial Pumps (CIP) Working Group. Members were tasked with developing efficiency and testing recommendations. The 16-member CIP Working Group presented ASRAC with 14 recommendations, including a market and technology assessment and analyses of screening, engineering, energy use, markups, life-cycle cost and payback period, shipments, national impact, and manufacturer impact.
Covered Equipment
The standards target specific kinds of rotodynamic or centrifugal pumps designated for pumping clean water in a variety of commercial, industrial, agricultural and municipal applications. Circulators and pool pumps are not included in this ruling. While the pump efficiency guidelines include pump motors, these motors are already subject to energy conservation standards and are not further regulated. The new DOE standards address up to 70 percent of commercial and industrial pump energy use. The following pump equipment classes are covered:- end-suction close-coupled pumps
- end-suction frame-mounted pumps
- in-line pumps
- radially split, multistage, vertical, in-line casing diffuser pumps
- submersible turbine (vertical turbine submersible pumps)
New Rating Metric
To rate the energy performance of pumps, the DOE established a new metric, the pump energy index (PEI). A PEI value greater than 1.00 indicates the pump does not comply with the energy conservation standard, while a value less than 1.00 indicates the pump is more efficient than required. A pump model is considered compliant if its PEI rating is less than or equal to the adopted standard. The test procedure contains methods for determining constant load pump energy index (PEI CL) for pumps sold without continuous controls (variable speed drives) or noncontinuous controls (multispeed motors), and the variable load pump energy index (PEI VL) for pumps sold with either continuous or noncontinuous controls. Both PEI CL and PEI VL describe the rated pump's weighted average performance at specific load points, normalized with respect to the performance of a minimally compliant pump without controls. The ruling requires testing methods for both constant-load and variable-load equipment classes. Manufacturers may also choose between test methods: calculation-based and physical-testing-based approaches. In addition to PEI CL and PEI VL, the following information is required for certification:- number of stages tested
- full impeller diameter
- whether the PEI CL or PEI VL is calculated or tested
- BEP flow rate in gallons per minute and head in feet when operating at nominal speed
- nominal speed of rotation in revolutions per minute
- driver power input at each required load point, corrected to nominal speed, in horsepower
