Inexperienced vibration analysts encounter a common problem: They are often expected to learn too much, too fast. Instead of taking time to appropriately understand the basics, new analysts must often move directly to a busy schedule of collection and analysis without much apprenticeship. Training is almost always in a group setting, and instructors often move too quickly through the material. The facts are learned well enough for an analyst-level exam, but an in-depth understanding is often taken for granted. Accurate vibration analysis requires complete clarity on foundational subjects. Real-world applications demand more of young analysts than what they can learn in group training. Facility operations depend on a whole picture of how their equipment moves and where energy is used—and lost.
Revisiting the fundamentals of data examination, time and resolution can solve equipment issues before they happen.
09/19/2014
Figure 1. An FFT spectrum (Graphics courtesy of LUDECA, INC.)
Figure 2 magnifies the 1× to 3× peaks. Unsurprisingly, it shows the 1× with multiples.
Figure 2. A magnification of the 1x to 3x peaks
The spectrum has an fmax of 384,000 cycles per minute (cpm) and 3,200 lines of resolution. The maximum possible resolution is 120 cpm.
Figure 3 shows a higher-resolution fast Fourier transform (FFT) analysis taken without moving the sensor. The 1× peak remains prominent with its multiples, but more data are shown in the skirts of these peaks.
Figure 3. A higher-resolution FFT analysis
Figure 4 zooms in on the higher resolution fft. The higher resolution analysis shows that one peak in the lower resolution fft was actually three peaks—the 1× peak and a sideband on either side of it. The sidebands are spaced at about 40 cpm from the 1×. The 2× peak shows even more sidebands at the same spacing.
Figure 4. A zoomed-in view of the higher-resolution FFT analysis
The yellow-shaded area shows the bandwidth of the lower resolution fft. In the lower resolution fft, the entire frequency range shaded in yellow must be shown as one peak because it is covered by a single line of resolution.
An analyst with access to only the lower-resolution fft might look at the harmonics of 1× and conclude looseness. The analyst might decide to trend it because all the amplitudes are low or, more likely, write a work order to repair the looseness. The real problem of cracked rotor bars would go undetected and only get worse.
Eventually, a rotor bar fragment would fly out during rotation and rip apart the stator of an expensive 1,250-horsepower motor.
Figure 5. A 0.5-second twf
Equation 1:
Where:
T = Time
R = Resolution
Figure 6 takes this 0.5-second twf and puts it on a time line of 2 seconds. The line begins at 0.75 second and ends at 1.25 seconds.
Figure 6. A 0.5-second twf on a 2-second time line
The two red x’s represent cyclic vibratory events that have a frequency of one second, or 60 cpm. The half-second of data collection completely missed the 60-cpm events. Even if it included one event, that would not have been enough for the fft analysis to calculate it properly.
This, in essence, is resolution. A signal processing engineer cannot create an algorithm to deal with incomplete data. More time must be given to collect a complete set of data—in this case, more than one second for 60 cpm of vibration data.
A minimum of two events are needed to display this vibration confidently in an fft. One second of data provides a maximum possible resolution of 60 cpm because, in 1 minute, 60 one-second cycles occur.
Equation 1 can be solved for R, showing that resolution is inversely proportional to time. Substituting the values from the example into Equation 1, the time of 0.5 seconds provides a resolution of 2 hertz—or, to convert to cpm, multiply by 60 for a resolution of 120 cpm.
Figure 7. A zoomed-in view of the 1x peak of the lower-resolution FFT
The fmax represents the entire fft—the higher the fmax, the larger the palette from which the spectrum is drawn. The number of lines of resolution represent the number of dots available to draw out the detail of the fft. A higher fmax requires more dots for better detail. High resolution and fine detail are often necessary to diagnose different and more complex faults.
