AL JUBAIL, Saudi Arabia (Jan. 17, 2014) – Metso has received significant orders for its Neles and Jamesbury valves from Sadara Chemical Company (Sadara), a joint venture between Saudi Arabian Oil Company (Saudi Aramco) and The Dow Chemical Company. The valves will be delivered for Sadara's fully integrated chemicals complex currently under construction in Al Jubail, Saudi Arabia. Metso received these orders during 2013. Metso's delivery includes automated control and on/off valves, emergency shut-down valves, as well as ball and butterfly valves equipped with intelligent valve controllers Neles ND9000. Many of the valves are of large diameter, sizing up to 80 inches. Metso's valves will control process flow in several process areas in the complex including the mixed feed cracker, downstream units and utilities. The Sadara complex will produce more than 3 million metric tons of high value specialty chemical products and performance plastics annually to be used in many industries, such as transportation (automotive parts, maintenance fluids), construction (pipes, adhesives & sealants), packaging and containers, consumer goods (foam for furniture and bedding; rigid for appliances), adhesives & sealants, coatings, oil & gas (pipeline coatings, sour gas treatment), and electrical & electronics. Metso is a valve solutions and services provider. Sadara is a joint venture between the Saudi Arabian Oil Company (Saudi Aramco) and The Dow Chemical Company.
Fri, 01/17/2014 - 00:00
