WASHINGTON (Jan. 8, 2015) – The U.S. Environmental Protection Agency (EPA), in conjunction with the U.S. Department of Agriculture (USDA) and the Ohio State University, has released a risk assessment concluding that silica-based spent foundry sands from iron, steel and aluminum foundries, when used in certain soil-related applications, are protective of human health and the environment and yield environmental benefits. “There is potential for substantial growth in the recycling of silica-based spent foundry sands,” said Mathy Stanislaus, assistant administrator for EPA’s Office of Solid Waste and Emergency Response. “Our risk assessment concludes that the evaluated reuses are environmentally appropriate. Advancing the environmentally sound, beneficial use of industrial materials, such as spent foundry sands, provides substantial opportunities for addressing climate change and air quality, enhancing state, tribal and local partnerships, reducing costs, and working toward a sustainable future.” Based on the results of the assessment, the EPA and the USDA support the beneficial use of silica-based spent foundry sands in manufactured soils, soil-less potting media, and as a foundation layer in road construction. EPA’s risk assessment of the evaluated uses concluded that they are environmentally appropriate because the constituent concentrations in the sands are below the agency’s health and environmental benchmarks. EPA estimates the environmental benefits from using silica-based spent foundry sands in the specific applications studied, at the current use rate, result in the following savings in one year:
  • The energy savings equivalent to the annualel ectricity consumption of 800 homes
  • CO2 emissions reductions equivalent to removing 840 cars from the road
  • Water savings of 7.8 million gallons
Foundries purchase virgin sand to create metal casting molds and cores. The sand is reused numerous times within the foundry operation itself. However, over time, the sands become unusable and are referred to as spent foundry sands. The spent foundry sands are then reused in a number of ways, including as an ingredient in potting soil and as a foundation layer in roadway construction. The risk assessment results are specific to silica-based spent foundry sands from iron, steel and aluminum foundry operations. Spent foundry sands from leaded and non-leaded brass and bronze foundries and spent foundry sands containing olivine sand are not included in this assessment. The EPA encourages foundries and foundry sand recyclers to consult state regulations to ensure planned uses are consistent with state beneficial use and waste management programs and that the chemical and physical properties of the sand meet applicable state environmental limits, engineering performance criteria and other state requirements. This report provides states, tribes and other interested parties with key information to support their foundry sand beneficial use decisions.
