Tue, 02/24/2015 - 00:00
ERLANGEN, Germany (Feb. 24, 2015) – Siemens is supplying two gas turbines and one steam turbine for the Holland Energy Park combined cycle power plant in Holland, Michigan. The plant will generate approximately 125 megawatt (MW) in summer and 145 MW in winter. The local municipal utility, Holland Board of Public Works (HBPW), is replacing a coal-fired plant with a new fuel efficient modern power plant. With the new Siemens technology the CO2-emissions at the site will be reduced by approximately 50 percent. A special feature of this plant is the use of surplus heat from the circulating water system for use in expanding a downtown snowmelt system. Commercial operation of the plant is scheduled for fall 2016.
