04/11/2014
First of Two Parts
Cavitation can severely damage pumps and is affected by pump design and system issues. What affects it most? Does the suction behavior from the discharge side (system) of a pump affect pump cavitation? Cavitation is initiated when the suction pressure drops below vapor pressure. However, does it matter how this pressure is reduced, and what is the system mechanism that can lead to the typical detectable noise versus cases in which, even if pressure drops substantially, no sound occurs? This column and Part Two in May will cover this topic.
Part One breaks down a video of two cases that are seemingly similar, but under closer examination, have significant differences. Learning the differences can help pump users better understand the basics of cavitation mechanisms and also how the system within which the pump operates can contribute to it.
Differences in low pressure initiation at the pump inlet is not the only factor to consider for an in-depth understanding of suction valve throttle versus vacuum pumping. A video of one of the live, hands-on exercises conducted during Pump School sessions shows each example and can be viewed at:
www.pump-magazine.com/pump_magazine/q&a/faqq111-120/faqq111_120.htm (Question #120)
![System sketch](/sites/default/files/0414/LevSketch1-0414.jpg)
![Development of cavitation](/sites/default/files/0414/LevSketch2-0414.jpg)
Note: This test is one of the standard exercises during Pump School sessions. For the schedule, visit www.pumpingmachinery.com/pump_school/pump_school.htm).
