Magnetic couplings improve reliability and safety when pumping hazardous fluids.
01/21/2015
Sealless centrifugal pumps with a magnetic coupling have become more popular among end users in the chemical industry. Rare earth magnets have reduced the costs associated with magnetic couplings by decreasing magnet mass and required horsepower. This innovation has lowered the cost of not only the coupling, but also the overall operating cost.
Seal Failures
Seal failure is one of the most common causes of pump maintenance and downtime. If the seal fails, fluid escapes along the shaft that connects the motor to the impeller. Even when maintenance is scheduled before a failure, the pump must be taken out of service to replace the seal. While mechanical seal technology has improved over time, the innovations often require additional equipment. Double mechanical seals, either back to back or in tandem, are common for harsh conditions such as chemical pumping. Maintaining the barrier fluid in these designs often means purchasing barrier fluid tanks, controls and even additional pumps. Gas seals are another option, but also require supporting equipment that poses the risk of failure.Wider Acceptance
At first, end users only considered sealless pumps when handling environmentally hazardous or lethal fluids. The initial cost of a magnetically coupled pump far exceeded that of a conventionally sealed design. However, as time passed, operators became more concerned with total cost of ownership than preliminary capital outlay. Magnetically coupled pumps began to show a true cost advantage. Sealless designs replaced mechanically sealed pumps that required yearly removal for maintenance. Service intervals and mean time between failures extended. Environmental emissions decreased, and end user safety improved. Operators now consider sealless pumps for services that, just a few years ago, they would not have—non-hazardous, but still difficult and costly to seal.How Sealless Pumps Work
In centrifugal pumps, the pump shaft transmits torque from the motor to the impeller. A seal prevents the pumped fluid from escaping down the shaft. The seal includes two parts, one stationary and the other rotating. Seal faces are typically made of carbon, tungsten carbide or silicon carbide (SiC).
Managing Thrust
In sealless pumps, wet end thrust balance is vital. The wet end floats, so shaft sleeves and sleeve bearings must handle the radial thrust from the impeller and rotating wet end. A stable fluid film and hydrodynamic force support the shaft assembly. The fluid does not lubricate the bearings because they do not come into contact. Axial thrust loads can pose risks during system upsets. The wet end is designed to reduce axial force from the pump, but startup rings, or axial thrust bearings, are often employed when the system experiences changes. When the gap between a startup ring and mating surface closes, the force from the other startup ring increases. If the suction pressure surges suddenly, the front startup ring gap would close and the rear startup ring gap would open. The pump automatically produces a counterbalancing force in the direction of the pump suction. When paired with silicon carbide (SiC) bearing surfaces, this design allows for the wet end to have no parts that would be considered routine maintenance parts.
