The worldwide abundance of shale oil and natural gas has changed the face of global refined fuels production, and MENA countries stand ready to play an important role.
12/03/2015
While many see shale production as a U.S.-only phenomenon, substantial shale deposits dot the globe with many countries and oil companies poised to potentially capitalize on this niche in oil-and-gas production dynamics. According to the U.S. Energy Information Administration (EIA), the North African nation of Algeria has the world's third-largest shale gas reserves—707 trillion cubic feet—trailing only China and Argentina. Libya has the fifth-most shale oil reserves with 26 billion barrels, behind only Russia, the U.S., China and Argentina.
![Image 1. There are many entry points within the shale oil production and supply chain where sliding vane pump technology can help optimize operations. (Images courtesy of Blackmer)](/sites/default/files/mena/1115/hxl8_application.jpg)
A Different View
The ultimate goal of oilfield drilling and recovery activities is to quickly and cost-effectively turn oil and natural gas into marketable refined fuels and other petroleum-based commodities. These fuels and commodities include gasoline, diesel, liquefied petroleum gas (LPG), kerosene, home heating oil, bunkering fuels, jet fuels and asphalt/bitumen. The process of turning shale oil into end products is different than the one required for traditional crude oil. Crude oil found in the prolific oilfields of Saudi Arabia, Norway and the Gulf of Mexico, for example, and produced through long-held methods is known as "heavy" or "dirty." This means it has a higher viscosity, specific gravity and molecular composition, all of which combine to make it dense, or much thicker than water. Heavy crude oil also has a sulfur content that is higher than 1 percent and contains aromatics, asphaltenes and other impurities. Oil that is produced from shale formations, on the other hand, is shown to have different chemical and physical properties than traditional crude oil. "Clean" shale oil is much lighter than "dirty" crude oil because of its lower viscosity and level of impurities, which means that it requires less processing during refining. Because of its composition, therefore, shale oil has different handling characteristics than traditional crude oil as it makes its way through the refining process. This requires modifications in the actual refining process and in the choice of pumping equipment that is used. This equipment serves many purposes, such as moving raw shale oil from storage into the refinery and, ultimately, transferring finished refined products to storage tanks and transport vehicles.Sliding Vane Advantages
For more than a century, sliding vane pump technology has provided reliable performance in a myriad of refined fuels transfer operations. The secret to the sliding vane pump's repeated success is found in its unique design and method of operation. Sliding vane pumps have a number of vanes that are free to slide into or out of slots in the pump rotor. When the pump driver turns the rotor, a combination of forces (centrifugal, mechanical push rods and liquid) causes the vanes to move outward in their slots and around the inner bore of the pump casing. This forms internal pumping chambers. As the rotor revolves, the fluid flows through the suction port and into the pumping chambers created by the vanes. The fluid is then transported around the pump casing until reaching the discharge port, at which point the fluid moves into the discharge piping. This design enables the sliding vane pump to deliver operational characteristics necessary for effective fluid transfer in oilfield production and supply, as well as refined fuels transfer applications. Specifically, those characteristics are:- high suction capability
- line stripping
- dry-run capability
- self-priming operation
- volumetric consistency
- non-slip operation
- non-galling
- superior product sealing
- high or low flow rates
- easy maintenance
- stationary, skid or truck mounting
- stainless-steel, ductile-iron or cast-iron construction
![Image 2. Sliding vane pumps are rapidly becoming a first-choice technology for use in shale oil applications, from the wellhead to the delivery of shale-based refined fuels.](/sites/default/files/mena/1115/HXL_cutaway.jpg)
![Image 3. Sliding vane pumps feature a wide range of operational characteristics that enable them to reliably handle less-viscous shale oil, including dry-run capability, self-priming and non-slip operation, and volumetric consistency.](/sites/default/files/mena/1115/TXH35A-cutaway.jpg)
