Remote monitoring software prevents damage and downtime related to sealing problems.
04/10/2015
At every oil and gas facility, the ability to detect leaks and related problems quickly and accurately is a top priority. Leaking equipment can slow production, lead to costly damage and create unsafe working conditions. Incorporating remote monitoring software solutions and accompanying technical support is an important step in reducing faults and failures that can compromise the success of an oil and gas operation.
Leaking Pump Seal
In late December, a software monitoring solution at an oil and gas facility detected fluctuations in barrier fluid seal supply pressure on a pump equipped with a pressurized double seal. This pump had recently been started after several months of outage.
