In today's industrial landscape, remote monitoring of rotating assets is critical for reliable operation. Specifically, vibration data from pump bearings and other monitored points allows users to analyze the data spectrum and identify problems, such as shaft misalignment and pump cavitation. The effective use of vibration technology begins within the context of a well-managed predictive maintenance program. When not caused by improper installation, rotating machine failure is typically caused by component wear that can result from multiple sources, including a lack of proper maintenance, shaft misalignment, incorrect balance, damaging harmonic frequencies, lubricant type or misapplication. End users, however, can mitigate these common problems by using vibration monitoring to quantitatively monitor and diagnose the root cause of failure. Condition monitoring is a powerful solution in the arsenal of effective predictive maintenance programs. While this technology and methodology is often well documented, understood and applied, today's economic climate and a growing shortage of skilled labor in North American facilities have led to a scarcity of experienced people to perform and manage these programs. As a result, many areas of preventive maintenance are neglected or suffer because of budget, manpower and training constraints. Vibration monitoring is one part of a comprehensive predictive maintenance program, which typically includes oil sampling, performance testing, thermography and other types of well-established testing procedures. The long-term sustainability of manufacturing plants will continue to depend on this frontline defense to ensure process uptime and throughput into the foreseeable future. One common way to capture vibration data is the use of portable handheld probes that incorporate accelerometers. These devices can also be installed on the equipment itself. The technology is easy to use, and the stainless-steel sensor housing protects the accelerometer, which operates across a wide frequency spectrum and temperature range with high accuracy and repeatability. Most plants rely on vendor-specific application programs to consolidate and analyze collected vibration data. In many cases, however, the actual vibration spectrum is not collected and only vibration levels can be established. For those sites that collect data in an inconsistent manner, the lack of a well-structured vibration monitoring program can result in the following issues:
- Failure to collect data because of time constraints, lack of manpower or proper equipment
- Data is collected using inconsistent techniques or in different XYZ planes
- Data may be misinterpreted or anomalies can be undetected
- Failure to transfer captured data to the appropriate database
- Failure to capture baseline data after refurbishment
- Demands on existing wireless devices and networks
- Battery backup system, which also requires ongoing maintenance
- High bandwidth required because of the large volume of data sent over the wireless link
- Dynamic range, low noise levels, high-level processing capabilities and ability to capture data at the right time
- Sensitivity (proper selection) and durability of the wireless sensors
- Qualified people to analyze data; all equipment is analyzed by the same person using the same equipment
- Single point of data entry into the predictive maintenance database
