Pumps & Systems, October 2007
Frequency Hopping Spread Spectrum (FHSS) radio was invented during World War II by the military for communicating information and strategic plans to allied forces in a way that would counter enemy efforts to "jam" or intercept traditional radio communication frequencies.
The flexibility of the technology, reliability of communication links and the ability for spread spectrum to overcome interference has made it a preferred technology source for many decades. Now, FHSS is being used in applications across the planet.
Technology Overview
FHSS is accomplished by hopping within a specified bandwidth. These frequency bands are commonly referred to in the U.S. as ISM (industrial, scientific, and medical) bands. The ISM bands are, in turn, often referred to as 900-MHz, 2.4-GHz, and 5.8-GHz.
The most commonly used ISM band for industry is the 900-MHz band, which actually covers the 902-MHz to 928-MHz spectrum. This 902-MHz to 928-MHz spectrum can be divided into sub-frequencies. Some manufacturers can divide the spectrum into as many as 112 sub-frequencies.
spread spectrumA spread spectrum diagram showing a typical frequency hopping pattern. The numbers above the waveform peaks (1 through 16) represent a typical frequency hopping pattern. The pattern is the result of a sequential preset algorithm designed to maintain synchronization between the master and remote radio modems.
Additionally, the hopping patterns used to avoid interference should be robust and flexible enough that, in the event of extreme interference, the radio can and will hop away from interference at a speed that any unwelcome networks or thieves cannot intercept or disrupt communication.
The sophistication behind FHSS technology is that the radio can hop within the specified band as quickly as possible from one frequency to another in order to avoid radio interference and send the required data in packets.1 The faster a radio hops across the spectrum, the more likely it will find channels with no interference.
When using FHSS the rule of thumb is, "He who hops fastest wins." A simple but accurate rule! If a radio hops 180 times per second, it is 18 times more likely to find an open channel than a radio that hops 10 times per second.
Additionally, it is critical that a radio device be able to accommodate the communication speed of the device it is connected to (PLC or RTU, etc.) and the communication interface (serial, Ethernet, 4-mA to 20-mA, or 1-V to 5-V).
It is also important that the radio be able to verify real-time communication of individual messages and be able to report if the message was received correctly or if the delivery was made with errors. One should never select a radio model or manufacturer that cannot determine and eliminate messages containing errors. The process used to check the integrity of a block of data is CRC (Cyclic Redundancy Check). A minimum CRC of 32 bit is recommended.
Do not accept a technology that employs error correction, as this leaves the decision to correct data errors and pass data up to the manufacturer. Instead, select a technology provided that automatically discards "bad" messages and resends the original message.
A radio can also have the capability to monitor the performance of the communication network (diagnostics). This feature allows the user to continually monitor, in real-time, the performance of the communications network and, if needed, use the diagnostic data to troubleshoot any performance deficiencies.
Performance Overview and Expectations
FHSS radios range from slow hopping, short range devices (such as those commonly found in home security systems) to high speed, long range mission critical devices. The upper end of these devices can communicate reliably at ranges in excess of 40-mi using no more than 1-W (30-dB) of power.
Uses for Spread Spectrum
Due to the global use of radio communication, various shortages (by geography) of available licenses for license radio systems, and the declining cost of technology (landlines, cell phone, satellite, etc.), the utilization of spread spectrum radio in water and wastewater applications is expanding at a rate never seen before.
Radio communication is now being used for communication and control in water treatment, lift stations, metering, flow control, SCADA and other applications. The reliability and flexibility of spread spectrum allow for multiple networks consisting of potentially hundreds of radios, each located in the same geographic area, with little or no impact on the performance of any of the networks.
Irrigation districts are monitoring and controlling automated gates, resulting in significant resource conservation. Wastewater facilities are monitoring chemicals and controlling processes which allow for more precise treatment methods and improved utilization of employees. The ability to gather, change and distribute current treatment conditions to other locations - in a matter of seconds - allows for better decisions in more real life situations.
Municipalities are measuring lake and flow levels and metering users in residential, commercial and agricultural segments of their service area. Where metal pipe is the primary vehicle for water transfer, radio is used to advance cathodic protection efforts to monitor the integrity of the pipelines to ensure that no cracks or breaches are occurring which could cause a catastrophic failure and lead to interruption and/or loss of delivery capability.
Spread spectrum radios are also used in various other roles, depending upon the over air-speed of the radio. An example of such varied utilization is the extended visual monitoring of facilities that require a higher level of security but are located in remote areas. High speed spread spectrum radios are deployed in remote locations (pump stations, limited access facilities, etc.) with Internet protocol cameras to remotely monitor sensitive areas.
The high speed radios can also be used as a high speed backbone. A backbone is a central wireless communication path where slower devices and/or networks can connect to a higher speed network. This application is similar to the fiber network many of us are familiar with and have installed.
The wireless version of this backbone is much less expensive, can be much more flexible and can more quickly accommodate the growth needs of your particular situation. You can even extend your current fiber network with the integration of the higher speed radios available with full Internet protocol functionality and security.
Summary
FHSS technology has been used for more than 50 years, in applications ranging from mission critical military complexity to more simple uses, such as monitoring, control and SCADA. The advancement of this technology brings tremendous growth to our ability to develop and employ streamlined processes.
The reliability and robust nature of today's FHSS provides a tool that can be used to more effectively manage our systems and objectives and win the battle of conserving our precious natural resource called water!
Keys to reliable communication1 More detailed information on this process can be found in a complete summary of the Federal Communication Commission (FCC) rules for Frequency Hopping radios on the FCC website at http://www.fcc.gov/.
