by Greg Stem
Pumps & Systems, February 2008
Transformer oil pumps have evolved dramatically over the past several decades. Once considered to be merely a replaceable routine maintenance item, comparable to say, a valve, these pumps are now almost universally recognized as a critical component of "forced oil cooled" transformers that require sophisticated engineering, high quality construction and systematic preventative maintenance.
When a transformer oil pump performs properly, it ensures maximum cooling to maintain the transformer's peak load capacity. However, impairments to the pump can result in costly breakdowns and potentially catastrophic damage to the transformer. Unfortunately, such impairments are notoriously difficult to detect and prevent in pumps that are designed and/or constructed inadequately.
Transformer oil pump manufacturers in the U.S. have provided worldwide leadership in addressing these problems by introducing design improvements and innovations such as ultrasonic sensors that monitor the condition of bearings. Major North American utility companies have also driven the development of high performance transformer oil pumps by requiring thermal, mechanical, sealing, electrical and fluid systems that provide dependable operation.
The Challenge
Pumping transformer oil is a demanding application. The pump must operate continuously, year after year, pumping high temperature oil and remaining hermetically sealed in harsh outdoor environments.
One of the most challenging aspects of transformer oil pump design is the fact that the transformer oil also functions as the pump's lubricant. The problem is that transformer oil is selected not for its lubricating performance, but rather for its ability to function as an insulator to suppress corona and arcing within the transformer and for its ability to maintain stability and good dielectric properties at high temperature.
Though highly-refined mineral oil works well inside the transformer, it is a poor lubricant for the ball bearing systems in many types of transformer oil pumps.
Wear of the bearing system and impeller can lead to the release of metal particles into the oil circulating through the pump, cooler and, ultimately, the transformer. As a result, the dielectric properties of the oil and insulation can degrade, potentially causing hazardous arcing.
Degradation of the bearing system and impellers, as well as impairments of motor windings, can also cause a reduction in pump flow and discharge pressure, which causes reduced cooling capacity. Leaking electrical connectors and gasketed surfaces can impair pump performance and allow the ingress of moisture into the oil, as well as oil leaks into the environment.
State-of-the-art pumps mitigate these risks in a number of ways, including improvements to bearing design, ultrasonic monitoring of bearing condition, and high quality construction. Properly designed new or remanufactured pumps take advantage of many of these advancements in transformer oil pump technology.
Bearing Design
Of all the design improvements in transformer oil pumps over the past several decades, the replacement of ball bearing systems with bronze sleeve bearings is the single most important.
Again, transformer oil provides a poor lubricant for ball bearings. In fact, ball bearings are a viable solution only when lubricated by heavier oil or grease. They fail prematurely when lubricated by lightweight, low-viscosity transformer oil.
Additionally, ball bearing pumps that are not operated continuously commonly fail as a result of false brinelling of the bearings caused by transformer vibration or slight flow caused by convection. False brinelling occurs when vibration pushes the lubricant away from a region it is intended to protect.
A situation that subjects a mostly stationary bearing to only oscillating or vibrating load may push the lubricant out of the loaded area. However, since the bearing only rolls small distances, no action or movement replaces the displaced lubricant. The resulting wear debris oxidizes to form an abrasive compound that further accelerates wear.
Though all U.S. manufacturers and some foreign suppliers have discontinued using ball bearings in transformer pump designs, existing ball bearing pumps can be retrofitted with pump-specific bronze sleeve type radial/thrust bearings and hardened steel thrust collars.
The key to the design of thrust and radial bearings for transformer oil applications is a large thrust face sleeve bearing for long life and minimum wear. These bearings must have proper surface finish and precisely positioned grooves to pass the oil and maintain an adequate lubricant film under all conditions.
Monitoring Bearing Wear
Reliable long-term performance of transformer oil pumps depends not only on the bearing and hydraulic design systems, but also on the ability to proactively detect wear, ensure effective and energy-efficient cooling performance, and protect the pump and transformer from damage and breakdowns.
A patented ultrasonic bearing wear monitoring system was developed to overcome the shortcomings of conventional transformer pump bearing wear detection methods based on sound, vibration, and oil contamination. Such methods proved inconsistent and unreliable, and were useful only after the pump entered an abnormal operating state or the verge of catastrophic failure.
By tracking rate-of-wear data over time, this ultrasonic bearing wear system provides advance warning and enables informed decisions about selective, preventive maintenance to protect equipment, avoid breakdowns, and optimize maintenance effort and expense.
The principle of operation of the ultrasonic monitoring system is not complicated. Six precision ultrasonic sensors are mounted in both thrust and radial bearings at strategic points on new pumps or remanufactured pumps from various manufacturers. A permanently mounted piezoelectric transducer emits a high-frequency sound wave to precisely measure the echo time that determines the distance between the sensor and the bearing surface, to an accuracy of 0.0002-in. Measurements are compared to baseline readings to determine whether any bearing wear occurs.
The temperature-compensated readings can be taken while the pump operates under any condition, without disassembling the pump, whether the pump is operating or not. The sensors do not affect the performance of the pump. In addition to the ultrasonic system, a shaft rotation sight plug that facilitates checks for proper shaft/impeller rotation is useful.
Construction Quality
Beyond the design and monitoring of the bearing system, a third consideration is the overall quality of construction, in terms of both material quality and manufacturing quality.
Pumps should be constructed of rugged cast iron material for the pump castings (casings, motor enclosures, and impellers) to provide long life in the field. High performance/high quality coatings (primer and top coats) should be applied to protect the exterior surfaces from corrosion.
All sleeve bearing pumps should have the bearing journals and thrust surfaces ground between centers to ensure alignment and surface finish. All pump shaft, impeller and motor assemblies should be dynamically balanced to assure long-term vibration-free operation.
Durable electric supply power cords also help ensure reliable transformer pump performance. These should be capable of withstanding ultraviolet rays, oil, water and extreme weather conditions.
The Economics
nvestment in high quality new and remanufactured transformer oil pumps has a high economic return. A good pump will typically cost much less than one percent of the cost of the transformer it supports, yet it provides long-term insurance against breakdown, damage or failure of the transformer. As all owners of large critical transformers will attest, a failure or major outage of this equipment can cause severe upheaval to the wellbeing of their electrical power distribution system.
High quality pumps also pay for themselves in lowered maintenance and replacement costs. Properly designed sleeve bearing pumps reliably perform 15+ years - more than 3-4 times the typical useful life of ball bearing pumps. In addition, pumps with ultrasonic monitoring systems are less costly to operate because preventative maintenance can be efficiently planned.
Greg Stem is the engineering services & rep. channel manager for Cardinal Pumps and Exchangers, 9321 Ravenna Road. Suite H, Twinsburg, OH 44087, 330-425-7146, Fax: 330-425-0900, www.cardinalpumps.com.
