Last of Two Parts
06/01/2015
This series discusses valves and fittings and evaluates how these devices affect the operation of piping systems. Part 1 (Pumps & Systems, May 2015) covered head loss, K value and L/D coefficient. You can read part 1 here.
CV Coefficient
The CV value is an indication of the capacity of a valve or fitting and is often used to describe the performance of control valves. The CV coefficient is often used to describe the hydraulic characteristics of elements in a pipeline. The definition of CV is the number of U.S. gallons per minute (gpm) of 60 F water flowing through a valve or fitting results in a 1 pound per square inch (psi) pressure drop across the device. For example, if a device has a CV value of 200, then when 200 gpm flows through the device, a 1 psi pressure drop would occur. Equation 6 describes the CV value.
Calculating the Head Loss Using K Value
Regardless of the method used to arrive at a K value for a valve or fitting, Equation 8 is used to calculate the head loss resulting from valves and fittings.
Cross Section of Valves & Fittings
Reference 1 has cross sections of types of valves and fittings and the corresponding K values or L/D coefficients. There are too many types of valves and fittings to present in this article, but some attributes can be generalized. For example, a full-seat ball valve with its straight-through design has a much lower L/D value than a globe valve through which the fluid must make four changes of direction and flow around the valve disk within the flow path. The type of valve employed is based on many factors. Leak tightness is an important factor, but when two types of valves meet the same requirements, it is recommended to use the one with the lower head loss. Another example of fittings with varied loss coefficients are elbows. A short radius 90-degree elbow has an L/D coefficient of 20, but a long radius 90-degree elbow has a L/D coefficient of 14. This may not seem like a significant loss, but it adds up. So do the associated costs. The pump must supply the energy that is lost across the valves and fitting.Cost of Pipeline Operation
To demonstrate the pumping cost associated with valves and fittings, calculate the operating costs for different types of valves and fittings. Equation 10 can determine the pumping cost.
The often overlooked performance of the multitude of valves and fittings adds up. They have a compounded effect on performance in a fluid operation and need to be taken into consideration for efficiency planning and optimization. Next month's column will investigate how the control elements operate and the role that these devices play in piping systems and their associated cost.
- Flow of fluids through valves, fittings, and pipe. (1957). Chicago: Crane
- Flow of Fluids through Valves, Fittings and Pipe Technical Paper 410. © 2013 Crane Co. Stamford CT 06902.
