Pumps
Reinforcing additives combined with a carefully selected base resin can create a high-performance compound for any application.
Block and bleed isolation capabilities improve safety and profits.
Metallics and plastics offer advantages for different applications.
An Indiana refinery used reverse engineering to solve multiple challenges with one custom pump.
Understanding the equipment's operation capabilities and how to calculate the required size is critical.
A solid cyber defense strategy can protect plant assets—even field devices and pumps—from dangerous and costly security breaches.
A caustic, high-temperature cleaning solution puts excessive demand on equipment.
Correct equipment selection and application saved an aluminum producer $36,000.
Xylem CEO Patrick Decker discusses the need for technological advancements to solve global water scarcity.
The value-added services that IoT technology provides could transform the pump industry.
Additive manufacturing also improves geometric tolerances.
This technique can accommodate different soil conditions and project schedules.
